stopping a fluent job in nohup
Old   June 1, 2005, 11:30
Default stopping a fluent job in nohup
Mark
We have set up a simulation with a batch file, and executed it using the nohup command in Linux. Is there any way of gracefully stopping the program before the end of the batch file. I.E. we believe it has converged and do not want to run it any longer.
Mark
Old   June 2, 2005, 07:10
Default Re: stopping a fluent job in nohup
korni
Hi Mark!
I guess your problem is that you don't have the *.dat-file if you kill the job...
The way I'm doing this is to write out a *.dat-file after for example every 500 Iterations and then kill the job after it's converged (an a *.dat file was written..).
This probably won't help you this time, but for the nest time maybe...
Sorry for my poor English and goog luck!
Old   June 2, 2005, 09:51
Mark
Thank you very much for the suggestion. We are currently writing data at intervals to determine when convergence is reached. We are just unsure if killing the Fluent job from the "top" command in linux is a safe thing to do (i.e. does this release the Fluent licence?), but furthermore, it is not sufficient for parallel jobs. The kill script is intended for this I believe, however, when we went to execute this, the computer just hangs.
Thanks,
Mark
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
running fluent parallel with MS job scheduler Shamoon Jamshed FLUENT 0 November 15, 2009 12:48
how to stop FLUENT batch job and save the results? sophie FLUENT 4 September 21, 2007 23:07
how to continue fluent job juliana p FLUENT 2 February 16, 2006 03:14
cfd job Dr. Don I anyanwu Main CFD Forum 20 May 17, 1999 15:13
