July 30, 2005, 19:45 |
CFD Sailing Yacht analysis
Hi Mates, I am currently involved with hydrodynamics of a sailing yacht and I am living some problems with getting reasonable drag coefficients. It comes out higher (around 3*10^-2) than it has to be, is there anyone who has solved a problem about that subject before, I want to learn which turbulence model is more appropriate for that type of problem and what more things do I have to apply on the solution?
Cheers |
August 1, 2005, 01:43 |
Re: CFD Sailing Yacht analysis
Hi!
Higher drag prediction is a common problem in cfd... Drag is induced mainly by the viscous forces (lift on the other hand by the pressure difference). What you should do is probably refine your mesh in the boundary layer where the viscosity has the most effect - use the low re approach... regards MATEUS |
CFD software capable of modal analysis? | Jim-gineer | Main CFD Forum | 4 | January 14, 2010 09:29 |
FDM vs FVM vs FEM in CFD analysis | ck5285 | FLOW-3D | 1 | September 1, 2009 10:51 |
Fluent parameters for sailing yacht analysis | Daniel | FLUENT | 0 | April 24, 2007 06:47 |
part-time-cfd | Michael | Main CFD Forum | 6 | February 2, 2000 12:01 |
CFD Analysis on Shock/Boundary Layer Interacton'-HELP | Mujahid S. Suhaeb | Main CFD Forum | 8 | December 1, 1999 17:14 |
