August 2, 2005, 04:44 |
turbulent pipe flow
How do i calculate boundary conditions for turbulence at the inlet and outlets? I have the reynolds numbers at these boundaries, and the diameters for the pipes.
Reading the user guide, I am assuming i use the turbulence intensity and length scale to define the turbuence. Does anyone have some good approximating formula's for these parameters? My model involves a compressible gas flow at 6000kPa (within a natural gas transmission pipeline). Thanks. |
August 2, 2005, 10:52 |
Re: turbulent pipe flow
Intensity (Refer Fluent manual for calculating turbulence intensity -> http://www.fluentusers.com/fluent/do...e180.htm#26619) and Hydraulic diameter (= diameter of pipe for a cylinder even if modeled in 2D).
August 2, 2005, 13:00 |
it is difficult to calculate them accurately. a thumb rule says that moderate intensity of 5% should be used. at the upper range, it can be 15-20%. i am not sure about length scale range.
Swarup. |
LES turbulent pipe flow | panara | OpenFOAM Running, Solving & CFD | 68 | January 26, 2023 11:34 |
Turbulent cyclic pipe flow, wall functions and y+ | clyde | OpenFOAM Running, Solving & CFD | 3 | March 17, 2014 06:08 |
LES transitional pipe entrance flow | hasanduz | Main CFD Forum | 2 | October 11, 2013 17:59 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Appropriate model for turbulent, steady state pipe elbow flow | milos | OpenFOAM Running, Solving & CFD | 4 | July 9, 2009 02:24 |
