combustion
Old   August 9, 2005, 06:43
Default combustion
chandu
iam doing laminar non premixed combustion. i have done the cold flow simulation.can any one tell how to proceed to combustion modeling .
bye
Old   August 9, 2005, 11:07
Default Re: combustion
Swarup
I guess you set-up a complete model and included all specific requirements of the flamelet model including reaction. then,you turned them OFF and ran your simulation. this gave you a converged flow field. if this is what you did, then further things are: save the results of cold flow simulation in .dat file. turn ON all your reaction inputs and energy inputs. read the newly saved data file to start with the already known flow pattern and start the simulation. your source terms and energy equation will couple with the other equations.
Regards,
Swarup.
Old   August 9, 2005, 11:09
chandu
thank u
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
Multiresolution + Turbulence + Combustion Raul Main CFD Forum 0 March 18, 2005 07:53
