How to import mesh from Ansys?
Old   July 25, 2005, 10:02
Default How to import mesh from Ansys?
Achilleas
Hello there ,
i prepare the mesh in Ansys but i can't import it in fluent. The documentation didn't help me. Any suggestions. How should i save the mesh in Ansys?
Thanks
Old   July 25, 2005, 10:12
Default Re: How to import mesh from Ansys?
edi ghirardi
I think you should import your ansys mesh into GAMBIT instead, then export it as a classic .msh file.
Hope this helps,
Edi.
Old   July 25, 2005, 11:18
Mehdi Ghoddosy
Dear Achileas:
I agree with edi. Export your model in ansys in IGES format and then import in in gambit using import IGES.
Best Regards
Mehdi Ghoddosy
Old   August 1, 2005, 10:18
Achilleas
Thanks a lot guys, but i run in to many problems with gambit. Is there a way to import directly from ansys?
Regards
Old   August 1, 2005, 11:57
edi ghirardi
Hi Achilleas
in your previous posting you said that "documentation didn't help", so I suppose that you read page 6-25 and following in Fluent User's Guide about importing ANSYS grids. What's going wrong exactly with that three ways?
I never tried, by the way, to do it by myself but I was not surprised to hear someone running into trouble trying to do it...It's common practice to import meshes others than .msh in gambit before (IGES better, as Mehdi said, or CGNS, Nastran surface meshes also work...) and then "translate" them into the common file format. What happened when you tried to do this?
Cheers
Edi.
Old   August 5, 2005, 12:24
Achilleas
Hi, the problem is that gambit cant run from windows. since it is basicaly an xwindows application
Old   August 9, 2005, 10:59
Angelina
Bank Darlehn Info Banken Geld Berechnen Schweizerkredit Konto Privatdarlehen Schufafreie Kredite in bar Kreditvermittlung
Import ANSYS CFX Mesh to Fluent Noureddine FLUENT 6 February 11, 2009 12:33
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
can I import a mesh from ANSYS to Gambit? Vincent CFX 1 June 2, 2006 05:48
Problem importing ANSYS mesh, please help Ankan Kumar FLUENT 1 February 2, 2003 08:38
Importing mesh files from Ansys into Gambit Srinivas FLUENT 2 August 6, 2002 10:02
