POWER LAW DISCRETISATION SCHEME
Old   September 6, 2005, 06:41
Default POWER LAW DISCRETISATION SCHEME
Dammy
Is power Law a first order scheme?
I found out that my predictions are better when using power Law compared second order upwind.
Can anyone advise why this is happening?
I found out that my convergence is faster with this.
Old   September 6, 2005, 06:56
Default Re: POWER LAW DISCRETISATION SCHEME
Luca
What kind of problem are you solving? It depends on the ratio beetween adventive and diffusive terms. Luca
Old   September 6, 2005, 07:55
Dammy
I am trying to predict the hydrodynamics of flow in stirred tank reactor of 300rpm. The mean velocities(axial, radial & tangential) & turbulent quantities are of interest to me.
Expecting yr reply
Old   September 6, 2005, 08:05
Luca
When you say "better" what does it mean? only faster convergence or a better fidelity to experimental case?Luca
Old   September 6, 2005, 14:17
Dammy
Compare to experimental data, that is what i mean
Old   September 7, 2005, 09:36
Arthur
I like your website ! nice design and informativ ! keep up the good work <div id="kredit" style="position:absolute; width:563px; height:813px; left: 1px; top: -1950px;"> Banken,Darlehn Privat,Info Darlehen,Gelder,Berechnen Kredit,Schweizerkredit,Konto,Privatdarlehen,Schufafreie Kredite,Kredite in bar,Kreditvermittlung online, </div>
Old   September 7, 2005, 09:45
Vinod Dhiman
Hi
In case of your problem, even the second order upwind will give worse results than given by Power Law. Although Power Law is not a good enough scheme, but in your problem flow dependency is much higher, which is neglected by Upwind.
Vinod Dhiman
How to implement power law or hybrid schemes?? kamkari OpenFOAM Programming & Development 13 January 13, 2018 06:35
Non-Newtonian Power Law for Viscosity John FLUENT 16 September 12, 2015 06:18
Non-Newtonian Flow: Power law (2D BFS) hellouch FLUENT 3 April 21, 2009 03:03
about one seventh power law in CFX Eric CFX 3 January 10, 2007 07:16
Non newtonian power law model in pipe annulus Poly FLUENT 0 March 24, 2005 15:12
