Gambit error: Indentifier currently open
Like Tree1Likes
  • 1 Post By John
Old   August 25, 2005, 01:35
Default Gambit error: Indentifier currently open
John
Can someone please help me with this re-occuring problem. When I am using Gambit, quite often the program is terminated internally, ie. something goes wrong and Gambit says it can no longer continue, or any other fatal error. When I attemnpt to open this file again, the following message is returned within the 'Gambit Startup' window.
ERROR: IDENTIFIER "3D Tee - VOF" CURRENTLY OPEN
usage: C:\Fluent.Inc\gambit2.2.30\ntx86\\gambit.exe
-def(aultsfile) file
-dev(ice) X11|XWIN|OPEN(GL)|GL|XGL|SBX|STAR(BASE)
-doc(umentation)
-geom(etry) WIDTHxHEIGHT+X+Y
-font xs|s|l|xl
-help
-id name
-inp(utfile) file (implies batch run and no gui)
-init(file) file (a journal file to run at startup of gui mode)
-new|-old
-proe proe_command
-res(torejournal) file
This has hapenned time and time again and it has wasted many hours of work. I desperately need advice on this. Thankyou.
Old   August 25, 2005, 01:47
Default Re: Gambit error: Indentifier currently open
John
I have solved the problem by deleting the files ending in '.lok'.
folan likes this.
Old   September 7, 2005, 10:29
Vinod Dhiman
Hi John
That's good. You always have to delete the .lok files. They are lock files.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
How to open a saved Gambit File? barkan FLUENT 5 September 1, 2012 05:53
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
