September 19, 2005, 07:50 |
Help needed to model gas-solids flow
Dear all,
me need help! Am trying to model a hopper flow. Am completely new to Fluent. The tutorials have that of an impeller liquid-gas but not solids-gas. After much reading up, I am still abit now where. Which turbulent model should I use? It is not mixture as the density of the secondary phase (i.e. solids materials) are much higher than the primary phase (air). It is not dispersed turbulence as the secondary phase is not dilute. (or is it? what is consider dilute? The solids are loaded into a hopper and made to flow out). Can i model it as laminar flow? Also the boundary condition at the outlet? Should I use outflow or pressure outlet? Things like velocity at outlet I do not know. I thought should be calculated by FLUENT? Please help if anyone can.Thanks a lot everyone. Juliana P |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model | us | FLUENT | 5 | April 5, 2011 02:29 |
gas flow out of a C-D channel | ljp | FLUENT | 0 | March 7, 2011 14:32 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
urgent help needed with 2d compressible flow | James | FLUENT | 2 | June 20, 2007 04:22 |
