Help needed to model gas-solids flow
Old   September 19, 2005, 07:50
Default Help needed to model gas-solids flow
Juliana P
Dear all,
me need help! Am trying to model a hopper flow. Am completely new to Fluent. The tutorials have that of an impeller liquid-gas but not solids-gas. After much reading up, I am still abit now where.
Which turbulent model should I use? It is not mixture as the density of the secondary phase (i.e. solids materials) are much higher than the primary phase (air). It is not dispersed turbulence as the secondary phase is not dilute. (or is it? what is consider dilute? The solids are loaded into a hopper and made to flow out). Can i model it as laminar flow?
Also the boundary condition at the outlet? Should I use outflow or pressure outlet? Things like velocity at outlet I do not know. I thought should be calculated by FLUENT?
Please help if anyone can.Thanks a lot everyone.
Juliana P
Old   September 19, 2005, 15:44
Default Re: Help needed to model gas-solids flow
Podila
Dispersed Multiphase K-e model as it treats turbulence in each phase separately. Pressure outlet.. Read paper by Davor Cockljat. It will help you to understand why dispersed k-e model has to be used.
laminar or Turbulent???? Calculate Nre for continuous phase.
Old   September 19, 2005, 23:08
Juliana P
Hi Podila and others who can help,
I tried to search for Davor Cockljiat. It produced the following : High performance computing for river engineering. Proceedings of the 1996 Parallel Computational Fluid Dynamics Conference, CFD, 1997, p 84. But I don't have access to it. Can you kindly send me at
juliana.pesma@gmail.com
if you have the paper. Will this paper help me loads? How do I determine the boundary conditions, is it through trial and error or are there papers to read? Really thanks for your help.
Also I want to ask what is Nre? you mean reynolds no.is it? How to calculate if I do not know velocity? Re= (density x velocity x characteristic length) / (kinematic viscosity) right? Many thanks again.
thanks Juliana P
Old   September 21, 2005, 09:42
Podila
Cockljat, D. and V. A. Ivanov, F. J. Sarasola, S. A. Vasquez, "Multiphase k- models for Unstructured Meshes" ASME 2000 Fluids Engineering Division Summer Meeting, Boston, 2000.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 02:29
gas flow out of a C-D channel ljp FLUENT 0 March 7, 2011 14:32
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 04:22
