solid-solid interface
Old   October 11, 2005, 10:16
Default solid-solid interface
greg
Hi all,
i am having problems with my mesh. I am modelling an aerofoil in transonic flow. What i have is an aerofoil(solid zone) and an additional piece of mesh attached to it (also solid zone). However the attached piece of mesh is not conected along its entire length, sort of,
|addtional bit|
| what would be the aerofoil |
but when i solve the flow the solution diverges due to the energy. i have tried labelling each part individual as a wall so that i have coupled heat transfer but this does not work! any ideas?
Many thanks,
Greg
p.s. if the aerofoil and additional mesh is combined into one solid zone the solution will converge.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
