January 24, 2011, 19:31 |
boundary conditions
Rep Power: 16 |
hi
What is the difference between interior and interface boundary conditions and when they can be used properly in modeling? thanks in advance for your answer. best wishes, |
January 25, 2011, 01:18 |
Maxime Perelli
Rep Power: 41 |
*interior can be attached on a surface which is inside a fluid domain (understand one connected mesh). For instance in gamit, if your mesh is made of multiple connected volumes, then one interior-bc could be on split-surface
The only purpose of this kind of BC (from my side) is to get some info on this surface (like masfflow, or any average-quantity) *interface can be used if you want to "glue" 2 meshes without connecting them in gambit, but it is necessarly if you want to use sliding mesh (Single Reference Frame, Multiple Reference Frame, etc...). Typical example: rotor-stator interaction
In memory of my friend Hervé: CFD engineer & freerider |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
Pressure boundary conditions | Lionel S. | Main CFD Forum | 1 | August 24, 2007 18:03 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
