fluent warning: SIGHUP signal
Old   October 17, 2005, 04:32
Default fluent warning: SIGHUP signal
Madhukar Rapaka
Hi
while running a simulation fluent gave me a warning: 'received SIGHUP signal' what is this...does it has any significance
thanks in advance
Old   October 17, 2005, 19:48
Default Re: fluent warning: SIGHUP signal
pUl|
One reason for that:
You must have closed or exited the terminal from which you started fluent.
Usually not a problem.
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[swak4Foam] installing funkySetFields prapanj OpenFOAM Community Contributions 65 October 8, 2015 17:46
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
OF14 compilation error bistreamb is already declared in this scope rafal OpenFOAM Installation 5 August 26, 2008 11:23
IcoLagrangianFoam_problem zhoubinwx OpenFOAM Bugs 2 May 21, 2008 04:55
