October 31, 2005, 15:03 |
DPM injection with RR distribution
I'm running a coupled, discrete phase simulation with a surface injection and a RR particle diameter distribution. Once the simulation ran, I took a sample at a line parallel to the injection rake (axisymmetric problem). However, the histogram of the diameter distribution shows an uniform distribution of the number of particles. Since the mass flow of particles is bell shaped, an uniform diameter distribution was not expected. I've also tried creating multiple surfaces and specifying the diameter and the corresponding flow rate, but I still obtain a histogram with a uniform distribution. If anyone has an idea what might be wrong, your response would be very much appreciated! Thanks, Dan |
November 1, 2005, 05:05 |
Re: DPM injection with RR distribution
Hello!
Maybe this thread can shed some light: http://www.cfd-online.com/Forum/flue...cgi?read=27795 /Henrik |
November 1, 2005, 09:29 |
Thanks, that did help!
I really appreciate the help. Dan |
DPM diameter mass distribution | Wouter | FLUENT | 5 | May 23, 2019 02:18 |
On DPM injection properties. | akr | FLUENT | 4 | October 23, 2006 10:54 |
DPM, UDF, Injection Type | Zhang | FLUENT | 0 | June 8, 2005 15:51 |
Group injection distribution | David | FLUENT | 3 | October 14, 2004 20:01 |
DPM Injection Parameters | Hendawi | FLUENT | 0 | June 13, 2002 09:41 |
