low massflow
Old   November 11, 2005, 02:09
Default low massflow
Anke Hentschel
This is Anke from Germany. At the moment I try to simulate the force on valve between two pressure chambers. These two chambers are connected with a short pipe. In the high pressure chamber is a valve. This valve looks more or less like a thin beam. Up to now the simulation model works very well. At the moment I try to do a simulation with a small mass flow. My problem is that, if I work with a very small mass flow (0,004kg/s) and with a little pressure difference (0,03bar) between these two chambers, I assumed to have a very small force on the valve. But something went wrong. If I have zero mass flow, I still have a force one the valve and this is impossible. I had discussions with my colleagues I contacted a university professor, but nobody could answer my question. I guess it could be a problem with numerical solver algorithm, because of the small mass flow, but I am not sure. So I would be very happy if you can tell me what the problem is and maybe what's the solution for my problem.
CU Anke
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 19:00
MassFlow Function? Absolute MassFlow? Failure in Caclulation eRzBeNgEl CFX 0 May 5, 2011 09:46
low massflow Anke Hentschel Main CFD Forum 1 November 11, 2005 14:11
2d axisymmetric: nozzle--> massflow too low?! Friederike FLUENT 2 May 9, 2005 04:51
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
