Sloshing: Turbulent/Laminar/Inviscid?!?!
Old   December 5, 2005, 16:38
Default Sloshing: Turbulent/Laminar/Inviscid?!?!
OD
I'm searching for opinions on the best way to model sloshing in a rectangular domain with air/water. The sloshing motion is pure sway motion: A * sin (omega * t). I have all the required UDF's, etc... I was just curious about the proper viscosity model. It seems that you can get away with inviscid flow for small amplitude waves. However, once you get near the natural period of the fluid you can get resonant conditions. Higher amplitudes lead to breaking waves and fluid hitting the tank top. I've tested all three viscosity models but what really dominates the flow?!
Old   December 6, 2005, 04:22
Default Re: Sloshing: Turbulent/Laminar/Inviscid?!?!
nasser
your model is turbulance you must use turbolence model
Force Window and sloshing mass satellite_control FLOW-3D 0 October 6, 2011 09:04
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 20:13
Calculating Sloshing mass in a cylinder satellite_control FLOW-3D 0 June 20, 2011 05:34
Sloshing frequency determination alastormoody11 STAR-CCM+ 0 January 20, 2011 22:40
Udf for sloshing problem D.Martelli Fluent UDF and Scheme Programming 0 December 9, 2009 11:21
