PROSTAR-----ICEM--------FLUENT
Old   December 16, 2005, 03:00
Default PROSTAR-----ICEM--------FLUENT
bono
Hello, everybody!
I generated a stuctured mesh in PROSTAR but I want to use it in FLUENT, so I exported the mesh from PROSTAR to ICEM first, then export the mesh from ICEM to FLUENT. However when I read the mesh into FLUENT, there is a warning message as follows:
WARNING: cell 19380 of thread 40 has NULL face pointer 5.Error: Build_Grid: grid error.
Clearing partially read grid.
Error: Null Domain Pointer
Error Object: ()
can any one give some ideas? Thanks in advance!
Old   December 16, 2005, 03:30
Default Re: PROSTAR-----ICEM--------FLUENT
HVN
Be sure that you have no trimmmed cells
Old   December 18, 2005, 00:28
nepie
you can export the mesh in nastran,then import it use gambit.
Export 2D mesh from ICEM to Fluent enghamed ANSYS Meshing & Geometry 18 August 10, 2015 20:49
[ICEM] domain interface in ICEM for fluent hsn ANSYS Meshing & Geometry 24 November 27, 2012 16:43
Dimension conflict between icem cfd and fluent highhopes ANSYS Meshing & Geometry 1 September 9, 2011 11:07
Problem with ICEM and Fluent: Automatically created Regions within the domain sandmike_83 ANSYS Meshing & Geometry 0 September 24, 2010 05:42
ICEM 2d mesh to fluent hsn CFX 2 June 5, 2008 14:45
