December 28, 2005, 12:12 |
what does the temperature limited means to?
i am getting this messege when itterating: "temperature limited to 5.000000e+003 in 29 cells on zone 2 3 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 1.3473e-05 0:13:18 997 " can someone explain what does this mean? Thanks , Roee
December 28, 2005, 16:04 |
Re: what does the temperature limited means to?
the calculated temperature exceeds the limit of 5000, which is set by the reference values (you can increase that limit and see what happens next
December 28, 2005, 16:21 |
wowww great thank you very much.
December 28, 2005, 16:29 |
Hi again. Where can i increase the limit of the temperature? Thanks, Yosef
December 30, 2005, 05:37 |
By default max and min values of tamperature is defined as 5000k and 1k. u can change it from:
Solve --> controls --> Limits |
December 2, 2013, 14:49 |
#6 | |
zahra
temperature limited - absolute pressure limited | Asashi | FLUENT | 3 | July 18, 2014 09:51 |
temperature limited to 1 in only one cell ??!!! | pipin | FLUENT | 5 | July 21, 2009 10:58 |
Limited temperature and pressure warnings | Shamoon Jamshed | FLUENT | 0 | July 7, 2009 16:20 |
pressure and temperature limited | Radwa | FLUENT | 2 | July 3, 2006 00:19 |
Sequential calculation of Temperature and mass tra | J.W.Ryu | FLUENT | 7 | June 18, 2002 07:12 |
