Fluent periodicity problem
Old   January 14, 2006, 12:47
Default Fluent periodicity problem
CFD_boy
Hi,I'm doing a simulation on a turbine rotor and i have a classical periodicity problem: i set the the rotational periodic type in boundary conditions; the turbine have 25 blades and so when i check the grid, messages correctly say that the angle is 14.400 degree. When i run the simulation results aren't periodic in static pressure and temperature on the inlet surface (the outlet is ok). I can't found the reason, i think that maybe gambit generate a wrong grid but when i make the check i get no error messages. Does anybody have a suggestion for me? Thanks in advantage.
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
Fluent problem Z FLUENT 1 April 8, 2005 04:22
