Heat Transfer from Solid To Liquid!
Old   January 19, 2006, 17:52
Default Heat Transfer from Solid To Liquid!
Richard
I must be doing something wrong here! Im not getting any heat flux across the interface between solid and liquid! Ive set it as a coupled interface, so Im not sure why theres no heat flux.
Old   January 20, 2006, 05:43
Default Re: Heat Transfer from Solid To Liquid!
Laika
Why do you believe there is no heat flux? Because you don't see any in the contour plots, or because the numerical value reported by Fluent for the heat flux is exactly 0.
Is is a stationary calculation or transient? Does the solid has a heat energy source or somewhere a fixed temperature?
good luck, Laika, still orbiting
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
No Heat Transfer between two solid domains Mike ZH CFX 7 July 26, 2008 16:50
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
