unable to track particle(single injection)
Old   January 20, 2006, 00:04
Default unable to track particle(single injection)
Avinash Kumar
i got a problem while tracking the particle in flow using DISCREET PHASE MODEL. My problem consists of caturing of sand particles ( single injection ) in a duct (2-D).the particle has to either captured by a water drop which is located in the duct or escape .the flow is axis symmetric along the horizontal axis of duct and the water drop is on the axis.When i inject a particle offset to the axis from entrance of duct FLUENT tracks particle for a range of offset distances (approx till Y= 0.4times of drop diameter)but after that when i increase offset distance FLUENT is unable to track particle at the point of injection only.This happens for different diameter of particles at different offset distances. sum of the data tht i used is as follows (laminar flow ,drop dia = 100 micrometre particle dia=2 micrometer, velocity of flow = 5 m/s i.e. Re=32 , Fluid=air) Inlet boundary condition=velocity inlet oulet B.C= Pressaure outlet Drop=as a wall
DRAG RELATIONSHIP USED IN DPM= spherical law no interaction ENERGY EQUATION NOT TO B SOLVED.
If anyone can help me please mail me at avinashkumar79@yahoo.com
surface injection or point injection? sukura_1984 FLUENT 0 September 2, 2009 09:26
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
DPM, UDF, Injection Type Zhang FLUENT 0 June 8, 2005 15:51
Unable to Locate Injection Dan Dressler FLUENT 0 April 3, 2005 23:51
using injection file and parallel process Cindy Jones FLUENT 0 January 23, 2003 12:40
