about the coupled solver
Old   January 27, 2006, 14:08
Default about the coupled solver
Ian
does anyone know what the coupled solver intend to? can someone explain when and why should i use this kind of solver? best regards, Ian
Old   January 30, 2006, 11:53
Default Re: about the coupled solver
Sandra
Hi Ian,
The coupled solver will solve all equations (conservation equations for mass, momentum and energy) simultaneously instead of sequentially (=segregated from one another). You should use the coupled solver when the velocity and pressure are strongly coupled (high pressures and high velocities). Very long calculation times can occur when you use the coupled solver. You can also find more information concerning the coupled solver in the User's Guide.
Greetz, Sandra
Old   January 30, 2006, 16:36
Ian
Thank you sandra, That was the exact answer i needed Cheers If you need something don't afraid to aks me.. Bye
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 10:21
coupled solver wont work in star ccm+ richie Siemens 5 November 4, 2008 04:51
coupled solver problem danel FLUENT 0 July 5, 2004 02:17
coupled solver / uncoupled solver Jaan Unger Main CFD Forum 0 September 3, 2002 08:30
Re: Coupled solver + RNG K-e Model JN FLUENT 1 April 22, 2001 16:34
