February 7, 2006, 03:45 |
Fluent - Windows XP-Prof 32bit - 4 GB RAM
Hallo,
you can manipulate XP (32bit) to allocate 3 GB-RAM/task. 1 GB is then for XP. Who has experiences with Fluent/Gambit running such big models with a single processor? 1) Is it possible? - Or are there limitations by the c-compiler allocating more then 2 GB/task under Windows XP? 2) Is Fluent/Gambit running stable with such big tasks? Regards Peter |
February 9, 2006, 04:13 |
Re: Fluent - Windows XP-Prof 32bit - 4 GB RAM
I use Fluent on 4gb RAM Machine, but with two Xeon processors. I can say that the memory management is largely limited. From my experience Fluent would not run when allocated slightly more than 1.2 gb per process. I use 3 mln cell grid and have to enable hyper threading to simulate 4 processor machine to distribute RAM into smaller chunks. On 2 processors, Fluent gives me out of memory errors.
February 10, 2006, 01:21 |
Hi there!
I use not Fluent but other software and faces same problem. I have 2 xeon and 4 gb ram, but limit for 1 cpun seems to be around 1.2 gb as already mentionend. I am running under win 2000 and think this problem is more related to ms windows? Tom |
February 10, 2006, 11:12 |
You should check if windows XP doesn't limit the memory allocation to Fluent. More info: http://www.microsoft.com/whdc/system...AE/PAEmem.mspx Best regards
February 12, 2006, 09:36 |
Use LINUX OS Windows is good for office work and documents
February 14, 2006, 12:05 |
Hi
We use Fluent with 5 Intel-IV processors, one as master and four as slave. All of them have 2GB of memory and they work fine, however, the OS is Linux and not windows. Windows cannot handle such large simulations. Fluent can but with Unix based OSs. Vinod Dhiman |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Is the fluent mesh generate in windows can be used in linux? | panda60 | OpenFOAM | 7 | October 19, 2009 11:51 |
Any Luck with 64-bit FLUENT on 64-bit Windows? | Dylan | FLUENT | 4 | October 17, 2007 11:14 |
COMPATIBILITY OF FLUENT WITH WINDOWS XP | varghese | FLUENT | 0 | February 12, 2002 06:09 |
Can FLUENT run under Linux with 2 Gb of RAM? | Paul Gregory | FLUENT | 0 | February 13, 2001 20:10 |
