February 14, 2006, 23:24 |
grid view in fluent
I am solving a natural convection problem in a room using fluent. The hexahedral grid for the room was developed in gambit. When I import the *.msh file in fluent 3d, and view the grid in any cut section, I observe a random curve in any cut section. All along the curve cells have random lines cutting across them. Some times these lines form diagonal and sometimes not. Some of these cells even have more than one line cutting across the cell. This odd behaviour is seen only in cells along a curve. Infact this curve I see is imaginary and appears due to these irregular cells only which are showing extra line through them. All other cells look perfect squares.
This problem is not removed by smoothing the grid. More over such irregular cells are not visible in gambit. Gambit view is as per expectation. Can Any body give the clue to this behaviour of fluent. My other colleagues have also reported this feature. Thanks in advance. nirupam |
February 15, 2006, 02:23 |
Re: grid view in fluent
do u use 2 ore more licences? If so, Fluent divides the geometry in 2 or more parts, and what u see might be the plane, where the parts are attached.
February 15, 2006, 06:50 |
I have esperienced the same. Quite annoying if you have several slave machines. Any chance of removing the odd line?
February 16, 2006, 00:29 |
Dear Ralf,
No I am using only one license. This problem is seen in all the cut-planes, at any level and in any direction. There is somthing else to it. thanks nirupam |
February 15, 2006, 08:27 |
You stated the reason yourself... "This odd behaviour is seen only in cells along a curve"
What's happening is that your cut isn't perfectly aligned with the cells. When you create a surface, wherever that surface intersects an edge, you will get a vertex, whenever it intersects a face you will get an edge, and whenever it intersects a volume, you will get a face. If the face is perfectly aligned with the surface, then you will see perfect faces on your surface, but otherwise you will see what looks like a mess of lines. Once your mesh is built, there's really nothing you can do about this. If you know you want these cuts in advance, then you can build them into your Gambit model before meshing. If you're just trying to create images of the mesh, I recommend doing it in Gambit using the Examine mesh feature (icon on the bottom right of the toolbar... looks like a yellow grid with a magnifying glass over it). Hope this helps, and good luck, Jason |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent Grid Check: Left-handed & right handed face | Haider | FLUENT | 3 | March 22, 2009 23:01 |
Using SmaggICE Grid in Fluent | Kevin | FLUENT | 0 | September 23, 2008 11:54 |
Fluent View Factor Exportation | Scott | FLUENT | 2 | July 25, 2005 01:38 |
Grid for Fluent v.4 using Gambit? | Ray | Main CFD Forum | 3 | October 27, 1999 12:35 |
