UDF Compiling error LNK1181
Old   February 20, 2006, 12:33
Default UDF Compiling error LNK1181
marion
When I try to compile a udf in Fluent, I get a fatal error LNK1181. Here is the transcript of the message:
LINK: fatal error LNK1181: cannot open input file "fl6216s.lib"
Apparently, I don't have the right linker version. I have V3.00.5270 whereas I should have Version 6.00.8447 (from the installation FAQ fluent website).
I tried to install the latest Service Package for Visual C++, as it is recommended on Fluent's website, but it still gives the same error.
Does anyone have an idea of what to do to fix that problem? How can I get the right version for the linker?
Thank you,
Marion.
Old   February 20, 2006, 23:04
Default Re: UDF Compiling error LNK1181
turbomachinery
Hi, when you install the Visual C++, you must add the environment variables at the same time of installing. your problem is led by the wrong environment variables or you didn't add any Environment_variables.
Old   February 21, 2006, 03:07
marion
I have checked the environmental variables again, and they are as they say they should be on Fluent Website. http://www.fluentusers.com/support/i.../udfguides.htm
Thanks for your help.
compiling udf at window Nt(64BIT) noa FLUENT 3 July 29, 2014 23:01
Compiling UDF on a cluster Adya FLUENT 1 December 14, 2009 11:30
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
