February 22, 2006, 10:23 |
Batch problems !!
Hi i try to run fluent in batch mode but i have some problems:
1/ how "Patch" value on fluid zone thanks to text command ? 2/ how run a transient case in batch ? thanks in advance |
February 27, 2006, 08:44 |
Re: Batch problems !!
I hope I understand your question. Below is an example from a journal file in which I've created several different areas inside my 2D face, then applied values for pressure, k, and omega to the whole face and different velocities for the different areas.
/adapt/mark-boundary-cells (inlet) 40 /adapt/mark-boundary-cells (otherwall) 40 /adapt/mark-boundary-cells (outlet) 40 /adapt/mark-boundary-cells (symmetricl) 40 /adapt/mark-boundary-cells (symmetricr) 40 /adapt/mark-boundary-cells (target) 40 /adapt/combine-registers 0 1 2 3 4 5 () /solve/patch () combination-r6 () pressure 20 /solve/patch () combination-r6 () k 10 /solve/patch () combination-r6 () omega 3000 /solve/patch () isovalue-r1 () x-velocity y -10 /solve/patch () isovalue-r3 () y-velocity y -20 /solve/patch () isovalue-r4 () y-velocity y 20 /solve/patch () isovalue-r5 () x-velocity y 20 |
February 27, 2006, 08:46 |
I forgot this forum strips CRLFs unless they occur in pairs. Try reading the version below.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
to run a replayfile in batch mode from UNIX | froztbear | ANSYS Meshing & Geometry | 4 | May 13, 2014 08:00 |
Running Job in Batch mode (EFD) | Nick Sessions | FloEFD, FloWorks & FloTHERM | 0 | April 16, 2008 16:44 |
Problems with batch run | Anmol Agrawal | FLUENT | 1 | November 23, 2005 19:57 |
Problems on Batch run | Cindy Jones | FLUENT | 2 | November 24, 2002 00:45 |
