Need help with a geometry problem >
Old   February 25, 2006, 18:10
Default Need help with a geometry problem >
Yumi
Hi, I am stucked on a question on my homework. Here is the problem: The diagonals of a rectangle are 8 units long and intersect at a 60 degree angle. Find the dimensions of the rectangle.
What I dont get is , what is "dimension"? This is supposed to be about the "Special Right Triangle" (30-60-90) (45-45-90) Theorems.
Any help will be appreciated. Thank you!
Old   February 25, 2006, 19:06
Default Re: Need help with a geometry problem >
Yumi
Problem solved, get it now Sorry for the trouble.
Problem with geometry sheth ANSYS Meshing & Geometry 7 August 17, 2011 09:30
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
Transient problem with changing geometry! Fascal FLUENT 4 July 5, 2010 10:11
How can FLUENT be used to model a transient problem with changing geometry? Fascal FLUENT 0 June 30, 2010 15:21
[GAMBIT] problem in importing Pro Engineer geometry :-( arash_7444 ANSYS Meshing & Geometry 3 June 14, 2010 02:06
