DPM time_of_birth UDF
Old   March 2, 2006, 15:42
Default DPM time_of_birth UDF
Lourival
Hy everybody,
I have some doubts about the time of the particle is injected.
For example, I would like to know the time at which the particle that hit some WALL in my DOMAIN was injected. Note that I don't wanna the time that the particles enters the cell, but the time that the particle was injected in my domain, so I can calculate how long it took to hit the WALL.
Looking inside of the "dpm.h" I found three different times:
1) p->state.time 2) p->state0.time 3) p->init_state.time
The first is the time that the particle hit the WALL, the second is the time that the particle entry to current cell and the third I thought that could be the time that the particle was injected. I thought so because the struct init_state is related to the state at injection, but the second and the third gives the same result.
Taking a look inside of the particle_struct I found the variable time_of_birth and it gives a time before that the particle hits the tube.
Am I right in taking the time_of_birth as being the time of that the particle was injected ?? Does someone have an idea ??
Lourival
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari Fluent UDF and Scheme Programming 0 August 19, 2010 03:09
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari FLUENT 0 August 19, 2010 03:01
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 17:45
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 09:02
