UDF for velocity inlet
Old   January 30, 2011, 23:36
Question UDF for velocity inlet
ZHAOHUI
Zhaohui Lu is on a distinguished road
Hi all,
Is there anybody know if UDF could define the velocity boundary which is related to time and space at the same time?
Thanks!
Joey
Zhaohui Lu is offline   Reply With Quote
Old   February 1, 2011, 05:45
Brian
General_Gee is on a distinguished road
Heya,
Check here for a UDF velocity profile that varies with space
http://www.cfd-online.com/Forums/flu...d-turbine.html
you can access the current time using
real current_time;
current_time=RP_Get_Real("flow-time");
you can then add this into the equation for F_PROFILE
eg
F_PROFILE(f, thread, position) = 1.73-((15-y)*(15-y)*1.73/(30*30))+current_time;
Good luck
General_Gee is offline   Reply With Quote
Old   February 3, 2011, 01:43
ZHAOHUI
Originally Posted by General_Gee View Post
Heya,
real current_time;
eg
Good luck
Thanks man. let me try it again!
UDF for inlet mass flow rate rahulsuresh89 Fluent UDF and Scheme Programming 1 October 16, 2010 17:06
Fluent UDF load and apply inlet velocity b.c. Knut Lehmann Main CFD Forum 2 June 29, 2007 04:53
UDF 3D inlet b.c. problem Andrew FLUENT 4 May 25, 2004 04:24
find the best inlet with udf Tuckbros FLUENT 0 May 20, 2004 12:56
Fluent6.0 UDF inlet velocity BC David FLUENT 5 September 7, 2002 02:07
