March 15, 2006, 05:33 |
porous zone valus as a function of x and y
is there a UDF, that can difine the prouse zone values like porousity and res. coef. as a function of x, y and z?? I have a volume, where the porousity varies within the space. I may develope a function or a table, to assign the values to coordinates. Can a UDF handle a lookup table to read the values??? Thanks Ralf |
March 15, 2006, 09:59 |
Re: porous zone valus as a function of x and y
Hi, Yes, the udf is define profile, but this is possible in Fluent 6.2. You can give the function there.
March 15, 2006, 10:27 |
ok... we have Fluent 6.2 .. or higher...
As it looks like, there will be only a lookup table with some discreate points, where the values are defined. So I need Fluent to do an interpolation. Otherwise I have to find a 2D function by myselve (the values are constant in the third dimension), that fits the values. And thats a lot of work for a large number of different configurations. Any Idea? |
March 16, 2006, 02:10 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Polynomial thermophysical properties and laminar porous Zone | vemps | OpenFOAM | 0 | June 28, 2011 10:22 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
