porous zone valus as a function of x and y
Old   March 15, 2006, 05:33
Default porous zone valus as a function of x and y
Ralf Schmidt
is there a UDF, that can difine the prouse zone values like porousity and res. coef. as a function of x, y and z??
I have a volume, where the porousity varies within the space. I may develope a function or a table, to assign the values to coordinates.
Can a UDF handle a lookup table to read the values???
Thanks Ralf
Old   March 15, 2006, 09:59
Default Re: porous zone valus as a function of x and y
Katya
Hi, Yes, the udf is define profile, but this is possible in Fluent 6.2. You can give the function there.
Old   March 15, 2006, 10:27
Ralf Schmidt
ok... we have Fluent 6.2 .. or higher...
As it looks like, there will be only a lookup table with some discreate points, where the values are defined. So I need Fluent to do an interpolation.
Otherwise I have to find a 2D function by myselve (the values are constant in the third dimension), that fits the values. And thats a lot of work for a large number of different configurations.
Any Idea?
Old   March 16, 2006, 02:10
Michael Bo Hansen
If you are lucky you can find a function that fits your data at www.zunzun.com
- Michael Bo
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Polynomial thermophysical properties and laminar porous Zone vemps OpenFOAM 0 June 28, 2011 10:22
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
