Not able to start a Supersonic-Calculation
Old   March 17, 2006, 12:04
Default Not able to start a Supersonic-Calculation
Gernot
I'm not able to start a supersonic-Calculation in FLUENT. Here the facts. Please check it! If there are any problems, please note me.
thanks a lot!!!
pressure_inlet: Gauge Total Pressure = 300000 Pa
Initial Gauge Pressure = 0 Pa
pressure_outlet: Gauge Pressure = 0 Pa
Solver: Standard k-Omega-Model
Steady
Coupled
Material: air - ideal gas
cp = constant
Therm. Cond. = constant
Viscosity = sutherland
thanks for your efforts
Old   March 18, 2006, 02:36
Default Re: Not able to start a Supersonic-Calculation
Prasath
Hi u put the static pressure in the place of Initial Gauge Pressure . For e.g For M2 For Po=295760 Pstatic is 37800 Pa.
Regards Prasatth
Old   March 18, 2006, 06:07
Gernot
Thanks Prasath,
How I can calculate the pressures at M = 2 ?
Automatically start new calculation after the one before is completed? (FLUENT 12.1) mars21t FLUENT 4 March 27, 2011 09:52
Using 'define init' macro to perform a calculation at the start of a simulation jonnythewlis FLUENT 0 May 21, 2010 07:23
CFD calculation from transonic to supersonic flow lawmc FLUENT 1 April 6, 2010 02:47
Warning 097- AB Siemens 6 November 15, 2004 04:41
Supersonic flow calculation Valery Ponyavin FLUENT 3 March 28, 2004 22:28
