To install two releases in one PC
Old   March 19, 2006, 12:55
Default To install two releases in one PC
twiti
I have had both Fluent 6.1 and 6.2 installed in one PC. How can I launch the release I wanted? If I run from command line or star menu (under windows) release 6.2 would be launched. How can I run Fluent 6.1 ?
Old   March 19, 2006, 15:37
Default Re: To install two releases in one PC
KP
How did you install the both version together? Thanks! KP
Old   March 19, 2006, 20:17
Ahmed
right click on the icon, select properties and check the target and start in, then make the changes you want.
Old   March 20, 2006, 03:32
HVN
There is no problem, you need to click on the version you want to use. For me, I have 2 icons: on for the regular version of fluent and another for beta of the next version of fluent.
install openfoam in fedora Ahmed Khattab OpenFOAM Installation 32 September 23, 2011 11:11
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
