dpm and edc convergence
Old   March 22, 2006, 07:34
Default dpm and edc convergence
luigi
i'm studing a combustion chamber feeded by injection of liquid kerosene. i use the dpm model with a plain orifice atomizer. when i simulate combustion with finite-rate\ed model everything is ok; the fuel evaporate fastly and burn with good efficency. if i use the edc model the droplet takes a longer time to evaporate and this cause the extintion of the flame in a region but the bigger problem is that the continuity and energy residual doesn't go under 10-2. i've tried to change under-relaxation factor but there's no changes. my setting for dpm are: steady particle tracking; 1 iteration per 10 continous flow it. edc- defalt settings an 1 iteration per flow it ( i tried to increase this value butnothing change)
Diesel Combustion with DPM simulation Kamil Sobczak FLUENT 2 March 29, 2016 04:58
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
DPM model problem wwa FLUENT 7 May 4, 2010 09:26
