Insert inlet velocity waveform
Old   April 18, 2006, 04:27
Default Insert inlet velocity waveform
Hila
Dear all,
I have a velocity waveform, given as a large set of points, and I would like to define it as the inlet velocity in my case file (in FLUENT). What is the best way to do that? I can build a profile file (UDF file), but I wonder if there is another way. I heard about FFT but I have no idea how to use this technique. Anyone?
Thanks,
Hila.
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 07:20
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 03:01
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
