DPM Evaporation mass balance problem
Old   July 2, 2015, 21:14
Default DPM Evaporation mass balance problem
HYUNGSIK UM
herr010 is on a distinguished road
Hello!!
I am running DPM simulation using 2-D Axisymmetric, Multicomponent Model.
I injec water-urea solution about 0.00038 kg/s and 380 parcels with 0.01 sec timestep.
I found that every injected particles are evaporated!! the temperature and the residance time is enough to evaporate every particles No escaped, No aborted, only evaportaed.
But when I see a 'mass flux report' , DPM Mass source is 0.000288 kg/s.
There is a big diffence between the mass I injected and the mass evapored in the domain.
I tried same simulation using a more dense mesh with double precision, the result is same.
how can i fix this?
herr010 is offline   Reply With Quote
Old   July 2, 2015, 22:37
HYUNGSIK UM
Now, I am running same simulation on 3-dimensional mesh with same setting.
I found that the mass balance is correct.
The mass of evarporated particles is same to what I setting on boundary condition.
I think this problem is orruring at 2-dimensional axisymmetic.
dpm, evaporation, mass
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Mass and energy source - evaporation neilduffy1024 ANSYS 4 July 16, 2013 23:50
combustion problem mcnair CFX 9 March 22, 2011 14:06
Mass balance problem! JADG FLUENT 4 December 27, 2003 10:40
Heat and mass balance problem Laurent FLUENT 2 October 15, 2002 10:52
