What is meant by Grid Independence Study?
Like Tree4Likes
  • 1 Post By FarhathAlam
  • 2 Post By manoj korde
  • 1 Post By roddyalan
Old   May 10, 2006, 04:46
Default What is meant by Grid Independence Study?
Khan
Hi
I am trying to model flow over an airfoil with Mach 0.1. Can any person help me in
a. What is meant by Grid independent Study? b. Can 2-D grid independent study be applied over 3-D?
Urgent help is requested.
Cheers
Old   May 10, 2006, 05:51
Default Re: What is meant by Grid Independence Study?
FarhathAlam
Hi, The coarse mesh which gives a solution which is invariant with the finer meshes . In your case ,if you have carried out analysis for an aerofoil with one particular mesh size and solution doesnt change if the same is carried for caorser mesh .the grid independence is said to be achieved. the coarse mesh is used for further analysis.
ahmedrezk82 likes this.
Old   May 10, 2006, 07:50
manoj korde
when u solve any cfd problem the solution should be should not be affected by the size of ur grid. Grid independence is done to ensure that ur solution is indendent on the grid size.we try to solve same problem with fine grid and see the variation in result .
ahmedrezk82 and Ali.nabavi like this.
Old   May 11, 2006, 06:04
Khan
Thanx for the response. So it means that grid independence study is for specific turbulence model and can't be applied across the models? Also can 2D airfoil grid independent study be applied for 3D wing?
Old   May 11, 2006, 06:08
FarhathAlam
No,it has to done seperately
Old   May 11, 2006, 07:15
sam
are u sure. that grid independece study is repeated for eachturbulence model
Old   May 11, 2006, 07:43
Farhath
grid independence study need not be carried for each turbulence model .it has to be carried seperately for the 3D grid.
Old   May 11, 2006, 10:41
Khan
I am confused. Does this means that for K-E and SA models, the grid will be different because i did 2D airfoil case on K-E model and got results with reasonable fine results which were varying less than 1% as we go towards finer grid. But once i applied same mesh to SA or K-W, i gave me different results.
So does grid indepence study really means " Single grid for turbulence models" or "Single grid for single turbulence model"?
Old   May 11, 2006, 13:22
Riaan
GRID dependency, not TURBULENCE model dependency. As you refine the grid, and you change your y+ values, make sure that your y+ values are still in an acceptable range for the various turbulence models.
Typically, for external aerodynamics, I will refine the grid until the solution does not change, then check the effect of turbulence models for that fine grid (assuming y+ is always in valid range)
Old   November 5, 2009, 09:35
roddyalan is on a distinguished road
Hi guys, dumb question, what do you mean by solution. Does it mean residuals become constant.
engineer.iman likes this.
roddyalan is offline   Reply With Quote
Old   July 2, 2015, 22:40
Mohammad Mahmudur Rahman
Mahmudrochy is on a distinguished road
It means any of the output parameters, such as velocity, turbulent KE, skin friction coefficient etc....
Mahmudrochy is offline   Reply With Quote
Grid independence study prasanth FLUENT 15 August 20, 2014 06:42
grid independence questions lucifer FLUENT 0 December 14, 2009 19:59
grid independence study in transition simulation littlelz CFX 4 March 30, 2009 07:16
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
A doubt on grid independence study G.Balakrishnan FLUENT 4 November 21, 2000 11:05
