journal file: how to change window for hardcopy
Old   May 11, 2006, 02:18
Default journal file: how to change window for hardcopy
Ralf Schmidt
Hi!
Can anyone tell me, if there is a command for the TUI or a journal file, that changes the window, that is used in the hardcopy-option? Can a new window be opened or an old be closed?
e.g. I am having two windows (one for displaying residuals, one for the results) and I want Fluent to run multiple cases. After iterating each case, Fluent should hardcopy both windows.
Ralf
Old   May 11, 2006, 03:47
Default Re: journal file: how to change window for hardcop
Gernot
display set-window
Old   May 11, 2006, 04:18
Ralf Schmidt
as far as I understand, in this menue are just options for setting the scale, axis, text that is displayed and so on...
What I want, is to switch between 2 or more windows!
Old   May 11, 2006, 04:44
Gernot
the comand to make window 1 to your active window :
display set-window 1
to switch back to 0 it is :
display set-window 0
there must be a hyphen between set and window
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
Problem with Boundary Conditions using a journal file T.S. FLUENT 3 July 27, 2009 08:31
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
