Modelling water waves with moving wall
Old   May 1, 2006, 23:48
Default Modelling water waves with moving wall
Shane
Hi. I am trying to create water waves to model a tsunami using Fluent. I am using a UDF to define the motion of one of the walls to create the waves.
Does anybody have information on wave theory as to how the motion of the moving wall relates to the motion of the fluid. Ie for a set sinusoidal motion of the wall with defined period, velocity etc, how does this relate to the period, velocity and height of water displaced? I hopefully just want to use a simple function such as V(t)=Vosin(wt).
Thanks in advance
Shane
Old   May 2, 2006, 23:42
Default Re: Modelling water waves with moving wall
san
if you vist student fluent web site, there is a example posted on wave generation technique. The name of example file is wave. i hope this will help you to solve this problem.
with regards san
Old   May 3, 2006, 06:22
Aussie Shane
Hey, thanks for the reply. I've done the tutorial "Simulation of Wave generation in a tank", is this the file you are referring to. It does contain a c file named wave? In this tutorial there is no information on how the velocity function given was chosen. If this is not the file, can u send it to me at shane_Dav71@hotmail.com. I'm trying to understand how for a desired wave period, wave length, wave height etc for a given depth of water, how to deterimine a suitable function for a moving wall to get my desired wave performance characterisitics.
Many thanks Shane
Old   May 9, 2006, 06:19
Oalid
Dear Shane. Kindly can you send me the tutorial of wave you have mentioned in you email oalidt@yahoo.co.uk My best regards
Old   May 11, 2006, 21:06
pablo cornejo
I would like to have that tutorial to.
Can you send it to me at pabcornejo@udec.cl ?
thanks in advance.
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
How to use UDF to define a moving wall lingo FLUENT 2 April 23, 2004 02:38
moving wall wim vos FLUENT 1 March 30, 2004 18:20
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Damage to Sea Wall due storm water run off HELP!!! Robertson,W. Main CFD Forum 1 June 8, 2002 10:06
