Error Message in Fluent
Old   May 19, 2006, 04:59
Default Error Message in Fluent
Tang Kuei
Staggered, lam, 2D, with 2 uds. After several iterations, a error message comes out as follow, "divergence detected in AMG solver: uds-1"
What can I do for this problem?
When I try to use coupled method, I will never meet this condition.
cheers,
Old   May 19, 2006, 07:03
Default Re: Error Message in Fluent
Siddharth Khowala
hi, i think there might be some problem with your first UDF,Just use the first UDF in isolation without using the other one in segregated solver.Divergence errors are generally observed when a quantity is being divided by zero.These errors i have experienced hence i think might be the case.Just check your udf ,if at the time of running your code somevalue becomes 0 and is it dividing something,then that might be the problem maybe u can write the entire data in a file and check them.Hope it helps
regards
Old   May 19, 2006, 09:12
TengKuei
My diffusivity and property are temperature dependent, so I need to do the iteration with coupled method?
Old   May 19, 2006, 09:41
Siddharth Khowala
hi I meant to say that if u have got to use both the udf together then it would be better to write the output in a file and check if any quantity in your first udf is being divided by zero by checking the files.
regards
Old   May 19, 2006, 10:14
Default Re: thanks for your adivce
TengKuei
Dear sir,
Thank you very much!! I'm tryin' to do that
Regards,
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
