July 6, 2006, 09:45 |
Porous jump BC
Hi everyone
I'm trying to simulate the flow inside a tube which has a specific injector. In my experimental set up, the tube is closed with a paper filter. In this way I have 3 BC : a pressure inlet (0.5bar overpressure), a porous jump and a pressure outlet(atmospheric pressure). My simulation is running for incompressible flow, but for compressible flow I always have the message :"divergence in amg solver : temperature". I've tried a lot of solutions I found on this forum but I've still the same problem. Does someone have an idea???? |
July 6, 2006, 11:07 |
Re: Porous jump BC
Have you tried with a little under relaxation factor on the energy equation? I`m working too on a similar project, with pressure jump...it doesn`t work very well...
[ICEM] How can I define different zones in ICEM? | llrr | ANSYS Meshing & Geometry | 14 | February 12, 2017 13:44 |
[Commercial meshers] Porous Jump creation problem | mulfal | OpenFOAM Meshing & Mesh Conversion | 4 | December 9, 2013 11:59 |
Porous jump in urban environment | samygero | FLUENT | 0 | February 14, 2011 18:26 |
Porous Jump | Naresh | FLUENT | 0 | April 25, 2007 15:36 |
Testing the integrity of POROUS media and por jump | Azman | FLUENT | 0 | July 31, 2006 11:11 |
