converting a solidworks file into a fluent file
Old   June 22, 2006, 15:16
Default converting a solidworks file into a fluent file
rhaul
i have a geometry made using solidworks,with .sldasm ext. i dont have any solidworks software so i may not be able to save that in any other format..even if there is any option of doing it.i was able to view the geometry using a solidwork viewer which i downlodaded from net.
any suggestion so that i can generate a mesh from that file by may be openning it in some other softwares. or any suggestions which might help me.
thank you rahul
Old   June 23, 2006, 05:11
Default Re: converting a solidworks file into a fluent fil
Madhukar Rapaka
you should save the file in parasolid (.x_t) format to export it in to Gambit and mesh it. then u can export this mesh file to FLUENT. regards, madhukar
Old   June 23, 2006, 16:04
rahul
i dont have the solidwork software. i just got the finnished file saved .sldasm . can i change it to parasolid format without solid wotks software.
regards rahul
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Converting .geo file into FLUENT Chie Min CFX 0 May 25, 2001 10:35
