How to do boundary layer meshing of a 3D diffuser |
June 26, 2006, 03:52 |
How to do boundary layer meshing of a 3D diffuser using gambit.which face should be choosen to start the boundary layer meshing thanks
June 26, 2006, 04:00 |
Re: How to do boundary layer meshing of a 3D diffu
hi
i think u need the bdry layers only when u define a face with a wall boundary condition. so start the bdry layer from a walll bdry and keep in mind that the mesh shud always be perpendicular or normal to the face. hope this helps. regards |
June 27, 2006, 07:46 |
thanks for ur response I try to create mesh bdry layer along the conical face using following parameters in gambit first layer- .001 first row(a)-5.18e-5 growth factor-1.2 total depth.-0013 no. of rows-10 Internal countinity- yes algorith-uniform trans. pattern- 1:1 trans row- 0 Face- conical face of the diffuser
But i get a trianglular bdry layer mesh at each of plane faces and nothing along conical face. plz, explain the reason and solution. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
A question on "Specifying Boundary Layer Deformation Smoothing" | didiean | FLUENT | 2 | January 16, 2012 21:39 |
Meshing cylinders with boundary layer using Gambit | Florence | ANSYS Meshing & Geometry | 5 | April 1, 2009 12:36 |
Inflation layers / boundary layer meshing. | andy2o | Main CFD Forum | 3 | February 22, 2009 09:03 |
Boundary Layer Meshing of a nosecone | Chris | FLUENT | 1 | March 15, 2005 12:42 |
