result problem...
Old   July 20, 2006, 16:54
Default result problem...
emanuele
my simulation is about supersonic flow (Mach=2) around a launcher vehicle model tested in wind tunnel.
My goal is match computational results with experimental ones. I have tested some structured meshes (from Gambit); the Cp is quite the same, but the skin-friction coefficient is very different and that make the Fluent Cd far from wind tunnel data (I think...)
I have used standard 1st order k-e turbulence model, with standard wall function (y+ < 80 for my boundary) and CFL=0.2.
I have changed mesh, CFL, wall funcion, but no good results.
Moreover, when I use 2nd K-e model, the result is worse than the 1st order one!
Any suggestion?
Thank you in advance,
Emanuele
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Problem with skew faces in simpleFoam... HelloWorld OpenFOAM 7 May 14, 2010 11:28
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
Problem in cyclone simulation JiChun FLUENT 4 May 18, 2002 07:45
