August 28, 2006, 04:34 |
Need help setting a boundary condition...
Hi, I have two quick questions: 1) Supposse that I´m working with a jet engine airplane, what boundary condition should I put for the engine air intake? 2) In the case of a car, wich boundary condition should I set for the air intake in front of the car (don´t know the name for that in english)?
Thank you! |
August 28, 2006, 05:56 |
Re: Need help setting a boundary condition...
It depends what you know. Do you know a mass rat per second? a velocity? a pressure?
Velocity inlet, mass flow inlet or pressure inlet should be good. For an airplane, you can use pressure far field (only if you've meshed far enough before your inlet). Hope that helps ! |
August 28, 2006, 14:10 |
Perhaps I didn´t say something important, I want to work with the whole plane (including the press far field and also the engine), so basically I have to set two boundary conditions, my question is, how I have to set the engine intake to have a real flow behaivor around the plane.
Thanks! |
Setting the inlet boundary condition with inclination | saisanthoshm88 | CFX | 1 | October 4, 2011 06:41 |
Setting boundary condition for C-grid airfoil | quarkz | FLUENT | 0 | December 28, 2010 14:37 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
CFX Solver : Sudden crash | Hervé | CFX | 2 | June 16, 2008 06:40 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
