Error in Fluent
Old   September 7, 2006, 15:23
Default Error in Fluent
Vidya Raja
I'm running a pulsatile simulation in Fluent. I'm using the NITA scheme for the simulation. After a few iterations, I get an error mesage that says:
Error: Floating Point Error: invalid number
Error object: ()
What does it mean and how can it be fixed?
I started with the converged steady state simulation, then hooked the pulsatile velocity with the UDF, and then started the simulation with a very small time step size of 2*10e-5 with 200,000 time steps. The time period of the wave is 2sec and I want the simulation to run for 2 full cycles.
Can anyone tell me what could possibly be wrong?
Thanks.
Old   September 16, 2006, 22:04
Default Re: Error in Fluent
szw
hello, I counter the same question,but I have not solved the question if you know the answer please tell me thank you
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
