Periodic boundary and SRF
Old   September 18, 2006, 01:44
Default Periodic boundary and SRF
Alex H
Hi everyone, I'm looking at modelling a propeller, using Gambit as the preprocessor. The propeller has 2 blades, so i'm looking at using a periodic boundary such that i only have to model 1 blade.
I assume the control volume i will use will have periodic boundaries 180 degress apart since there are 2 blades. However i'm just not sure how a single rotating frame works - is there a cylindrical type sub-volume which holds the prop, outside of which is the external flow?
I'm getting a bit lost in all of this and am stuck on the best way to model a rotating propeller. Are there any good references for this type of modelling? At this stage, only the prop is being modelled, no engine/shaft etc. behind it.
Any help is appreciated,
Alex
Old   September 18, 2006, 02:33
Default Re: Periodic boundary and SRF
a
just look at help of gambit
Old   September 18, 2006, 10:53
ejaz benchot matherchut
I am The EXpert Of all Thing. Please Ask ME
Old   September 18, 2006, 12:25
manohar
i think, u can use SRF and for decision on control volume, u just go through the literature.
its possible. just go through the fluent user guide for single rotating frame
