September 22, 2006, 15:21 |
Naca 0012
For flow over a Naca 0012 airfoil ( compressible)...I set a pressure far filed boundary condition. The inputs I have to give for this condition are mach number,gauge pressure and temperature...for example I give the guage pressure of 101325 pascal,temp of 300k and mach number of 0.4. How can I calculate the reynolds number for that case
September 23, 2006, 09:20 |
Re: Naca 0012
It's easy. Initilize->Compute From, choose "Farfield", Fluent calculates automatically the velocity components. From that velocity, calculate Reynolds number!!!!!
September 23, 2006, 15:55 |
Re: Naca 0012
ya I know...but the density and viscosity change...so the reynolds number is bit different...
for exmaple for this example in student fluent can u tell me how did he get 10 to power 5 the reynolds number http://www.fluent.com/software/stude...al_airfoil.htm Thanks Ravi |
Naca 0012 validation, Cd value is too high. | Peter88 | OpenFOAM | 4 | January 21, 2014 16:10 |
How to import NACA 0012 Profile in Gridgen | maplepink | Main CFD Forum | 17 | May 7, 2013 13:01 |
NACA 0012 Case Will Not Converge | dancfd | OpenFOAM Running, Solving & CFD | 6 | November 14, 2011 19:09 |
Problems with flat plate and NACA 0012 Lift/Force | Harly | FLUENT | 0 | June 18, 2007 10:02 |
NACA 0012 simulation results | Luis | FLUENT | 3 | February 15, 2006 11:42 |
