temperature increased does not match the heat flux |
September 25, 2006, 03:34 |
I'm using FLUENT simulating a 3d model on conjugate heat transfer in a square duct. Water goes through a square duct(a laminar flow) and the duct is given a uniform heat flux. after the residuals and the parameters converged. the Area-Weighted Average temperature outlet is greater than than expected (about twice) the expected temperature is calculated as followed : (delta)t=Q/(M*Cp) FLUENT reported t=2*(delta)t can anyone help thans in advance
September 26, 2006, 00:02 |
Re: temperature increased does not match the heat
can anyone help~~~~~~~~~~~
this has bothered for a long time I still can't find out why the result like this |
April 6, 2010, 01:29 |
what are the units of the parameters in your equation please?
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
Wall Heat Flux & Temperature | Greg Perkins | FLUENT | 10 | November 20, 2015 09:32 |
heat flux distribution | gtheo | CFX | 2 | April 27, 2011 03:36 |
Constant heat flux with uniform temperature | Jake Lee | FLUENT | 2 | April 13, 2011 22:08 |
problem with heat flux in the wall | gholamghar | FLUENT | 1 | September 14, 2010 07:47 |
Constant wall heat flux with uniform temperature | Jake | FLUENT | 2 | September 29, 2003 11:34 |
