October 17, 2006, 03:10 |
wind tubine blade
hallo.. i'm a new user of gambit.can you help me with constructing wind turbine blade geometry and meshing it too.this is for my cfd class project.if any website gives all the data or tutorial on how to do that will be much appreciated.
regards kirua |
November 4, 2006, 10:41 |
Re: wind tubine blade
Can you elobrately describe your problem. what i think is if you can model the domain and the blade geometry in any surface modelling package and export it to gambit it would be easy to mesh the obtained model. or if you have the dimensions of the entire geometry then you can create it from a botoom up approach method in gambit. any way clearly specify what actually you need to do
November 13, 2006, 00:21 |
im constructing a blade geometry for wind turbine.im quiet cluless on how to do the geometry.can you please tell me more about the bottom up approach..
please help in simulating a wind turbine blade in 6 DOF ????.... | usman naseer | Main CFD Forum | 2 | March 10, 2016 02:53 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
Integral Force calculation in CFX 12 - wind blade case | LittleBart | CFX | 0 | April 27, 2011 04:04 |
Modelling of 2D Wind Turbine Blade (HAWT) | Richeom | FLUENT | 1 | August 11, 2010 04:18 |
Mathematical analysis of the cyclic stresses in the Wind Turine Blade Root | milindashokshende | Main CFD Forum | 1 | May 26, 2010 10:36 |
