custom field function
Old   November 30, 2006, 11:33
Default custom field function
Ana Raquel
hello everyone
this is my problem, I am trying that my velocity inlet will be not a constant value all long the pipe; and for that I am using the costum field function. but when I do the iterate fluent gives me an error: "divergence detected in AMG solver: temperature"
thus anyone knows how to solve it?
thanks
Raquel
Old   November 30, 2006, 15:25
Default Re: custom field function
Jason
Custom Field Functions don't modify boundary conditions. You either have to define a profile or write a UDF.
Also, divergence can be due to a lot of things. Boundary Conditions, mesh, geometry, solver settings... Check your mesh and make sure you're using the proper models for whatever you're trying to analyze. Also, look at the diverged solution and try to see what the problem is that caused it to diverge.
Good luck, Jason
How to calculate pressure forces using custom field functions? tsagaro FLUENT 7 June 23, 2017 15:45
Entropy Field Function in CCM? eRzBeNgEl STAR-CCM+ 3 August 22, 2011 05:15
Gradient of the Custom Field Function oghazian FLUENT 2 June 29, 2011 14:00
mean, variance and covariance statistics of any field function on any part. Subhadeep STAR-CCM+ 8 February 18, 2010 17:19
time step size in Custom Field Function Tong FLUENT 0 May 2, 2008 15:51
